1 - 13 of 13 Posts
I will be picking the truck up this Friday. It was purchased by its current owner to become a drag truck, I also desire to turn it into a street/strip truck.
Pros- Truck has LQ9 engine already, 2 turbos in the front seat, replacement panels for all the ones that currently sport rust.
Cons- truck lacks a transmission, driveline, radiator, steering rack.
My goal would be to put a built TH400, ford 9", newer power rack, and pull a radiator for it as well.
I'd like to be able to drive the truck while I piece together the turbo setup. What concerns, issues, problems do you see me having with this plan? I am mechanically savvy but a complete newbie with the C10.
Thanks!
All manageable by you I`m sure, very easy to work with, simple trucks, I may suggest buying a radiator from Champion rad, aluminum, if your truck was originally a V8 truck they are a bolt in..are you buying a used rack from something or new, Unisteer makes a nice unit thou pricey..rear trans crossmember will need to be changed out get one from any `73 to `87 c10 it will bolt in but further back to accommodate the th-400, you can buy the shims or wedges for the rear axle to mount on the trailing arms fro LMC or CPP.
So I've done a little more research and I'm thinking the 700R4 may be a better solution for my truck. I do plan to use it on the highway some so having an overdrive gear would be great.
700R4 good choice...what are you using for rear axle..?
For both cost savings and for less swapping around I was going to build the 12bolt. Being that I am running a mild LQ9 build with a pair of turbos I think that is the best bet for me. I've been looking at strange as they have some nice completely built/assembled setups but I also see the cost savings in learning to build it myself. Decisions decisions.
Current plans for the LQ9 are LS3 heads/LS9 cam/LS9 gaskets, arp head bolts. Maybe and very maybe springs/rockers. The LQ9 is only 20k old so I think it should be good for a while.
The stock GM 12 bolt will handle quite a bit of beating, many are still running them with built motors with no issues.
Is the motor already installed in the truck as the LQ9 will not bolt up directly to the mounts. Any pics of the truck?
Cool, rack and all....I`m jealous...! nice start on the truck...beer
Discussion Starter · #11 ·
I cannot take credit for the rack haha. The gentleman I purchased it from owns that shop. He has a similar albeit waaaay cooler C10 that runs 9's haha. He's helping me with this build. (thank god for a guy whos an expert on this platform). Hoping to be touching 10's and surprising some folks in the spring.
Discussion Starter · #12 ·
Haven't updated in a while. Have the following parts ready to start building.
Turbo headers
2x CXracing 62mm turbos
2x Turbosmart 45mm hypergate waste gates
1x Turbosmart raceport 50mm bov
th400 w/tbrake (1000tq build)
custom specced converter
CCP 6lug conversion w/discs
CCP pitman/72c10 steering box
Mishimoto radiator/hoses/160 tstat
CCP trans crossmember
(last thing I'm looking at is holley efi, not sure which EFI I want to run)
have the 29/15.50 R15's mounted and ready to rock
I'll post pics as we start the build.
1 - 13 of 13 Posts
