Welcome to the forum Tyler, yes a little more info is needed as Charlie said but if you are looking at auto trans you will have to build a crossmember as far as I know nobody makes one for the 60 to 62 x-frame trucks so this image here is from a ford crown victoria cut down with two end plates welded on....you won`t be able to build until you decide on on trans your going to use so you have a measurement ..!
