Chevy C10 Trucks banner
Discussion Starter #1
My only guess is that someone drilled these for mounting an antenna of some sort back in the day. I guess I’m looking for confirmation that is the case or if it was there from the factory then what is it for and where can I buy what goes there? I don’t have the welding skills to cover it and don’t want to body work and repaint the can either. Looking for advice as to what you all might do if you had the same situation?
Thanks,
5588
My 65 has the same hole. I was told it was where some kinda antenna (probably a cb radio) was mounted when my great grandmother bought the truck. Mine was a county work truck prior to her buying it in ‘68. There’s a no weld epoxy patch kit that eastwood sales that supposedly will patch up to a 2” hole but you’d still have to do a little body work and paint to fix it. I plan to weld mine but it isn’t in near that condition. I have a lot of body and paint work to go.
Discussion Starter #3
Thanks for the response.
