Help! - C10Trucks.com
C10Trucks.com
It shows that you are unregistered, or not logged in to The Forum. Please register with us by clicking Here
Click here to Join C10Trucks , Membership is Totally Free
How to make your first post on C10trucks.com Click Here.
Go Back   C10Trucks.com > Topics of Interest > Cooling Systems, Radiators, Fans / A/C
Cooling Systems, Radiators, Fans / A/C Cooling Systems, Radiators, Fans / A/C
Click here for C10 Truck Parts for sale on ebay
Reply
Thread Tools Display Modes
  #1
Old 11-03-2018, 03:04 PM
Johnnyb Johnnyb is offline
Junior Member
Default Help!
Hey,
I have a 64 C10 that I did an engine swap. Put in a new 350 SB, Champion 4 core radiator, Flex fan with long water pump. 180 deg thermostat.
Here's my issue, The truck takes forever to warm up enough to open the thermostat and during this time it starts puking coolant from the overflow line. When the truck warms up enough to open the therm it heats up past 180 deg to 200.
I replaced the therm thinking it was stuck open but it's still doing the same thing.
Any ideas? Help me before I pull whats left of my hair out.
4248
Sponsored Links
Advertisement
  #2
Old 11-03-2018, 03:08 PM
cfjfisher cfjfisher is offline
Senior Member
Default
there are several possibilities No fan shroud bottom hose collapsing is it a serpentine set up? Maybe water pump for reverse flow
4716
  #3
Old 11-03-2018, 03:37 PM
Junior Member
Default
I do not have a shroud. It doesn’t appear that the bottom hose is collapsing. And I have never heard of a reverse flow pump. Could I have put in the incorrect pump?
4248
  #4
Old 11-03-2018, 03:51 PM
Junior Member
Default
And no serpentine setup
4248
  #5
Old 11-04-2018, 10:02 AM
Senior Member
Default
I'd change the bottom hose to one with a spring in it, and see what happens. The later model Chevys with serpentine belts the water pumps run backwards to the older ones. Just one more thing to think about.
4716
  #6
Old 11-04-2018, 08:33 PM
Junior Member
Default
I also deleted the heater. I wonder if that has anything to do with it?
4248
  #7
Old 11-04-2018, 08:48 PM
406Rich's Avatar
406Rich 406Rich is offline
Default
No on the heater, you say this is a new engine, do you have the paper work with the engine part number, it will tell you if this is a reverse water pump, or did you buy the water pump separate ? One way to tell for sure remove water pump, looking at the front it should rotate clockwise, use a flashlight and look at the impeller vanes, the cupping should be facing clockwise...
__________________
`37 Ford Coupe, 406/350/324 posi
`64 C10, 350/350/373 posi
`68 Dodge Dart 370/904/325 sure grip
`69 Camaro RS/SS 350/350/307
"The difference between stupidity and genius is genius has its limits"...Albert Einstein
“Life is not a journey to the grave with the intention of arriving safely in one pretty and well preserved piece, but to skid across the line broadside, thoroughly used up, worn out, leaking oil, shouting GERONIMO!”
106
  #8
Old 11-05-2018, 09:10 AM
Junior Member
Default
I built the engine myself. Its out of a 72 Camaro. The water pump is for that engine and was bought from either Jegs or Summit. I will find the paperwork for the water pump and check the part number and see what it says.
Thanks for the ideas guys.
4248
  #9
Old 11-06-2018, 07:48 AM
406Rich's Avatar
Default
To much advance will also have a big impact on over heating, you say you have no shroud, What is the distance from the fan to radiator? Vacuum leaks...?
__________________
106
  #10
Old 11-08-2018, 12:03 AM
Junior Member
Default
I am about 12 deg before TDC. No vacuum leaks and the fan is about 3-4” from the radiator.
4248
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertisement
Partner Links
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
c10 trucks 67 72 c10 trucks c10 trucks for sale classic c10 trucks chevy c10 trucks used c10 trucks bagged c10 trucks slammed c10 trucks 1960 Chevy C10 Truck 1961 Chevy C10 Truck 1962 Chevy C10 Truck 1963 Chevy C10 Truck 1964 Chevy C10 Truck 1965 Chevy C10 Truck 1966 Chevy C10 Truck 1967 Chevy C10 Truck 1968 Chevy C10 Truck 1969 Chevy C10 Truck 1970 Chevy C10 Truck 1971 Chevy C10 Truck 1972 Chevy C10 Truck 1973 Chevy C10 Truck 1974 Chevy C10 Truck 1975 Chevy C10 Truck 1976 Chevy C10 Truck 1977 Chevy C10 Truck 1978 Chevy C10 Truck 1979 Chevy C10 Truck 1980 Chevy C10 Truck 1981 Chevy C10 Truck 1982 Chevy C10 Truck 1983 Chevy C10 Truck 1984 Chevy C10 Truck 1985 Chevy C10 Truck 1986 Chevy C10 Truck 1987 Chevy C10 Truck 1988 Chevy C10 Truck 1989 Chevy C10 Truck 1990 Chevy C10 Truck 1991 Chevy C10 Truck 1992 Chevy C10 Truck 1993 Chevy C10 Truck 1994 Chevy C10 Truck 1995 Chevy C10 Truck 1996 Chevy C10 Truck 1997 Chevy C10 Truck 1998 Chevy C10 Truck 1999 Chevy C10 Truck 2000 Chevy C10 Truck 2001 Chevy C10 Truck 1950 Chevrolet Truck 1968 C10 SNAKEBIT V-10 Hazel 1967 Chevrolet C10 BUILD 1968 C10 Chevrolet C10 Truck "5150" Plane Engine 68 c10 DINOS 1964 Chevrolet C10 DUALLY 1971 Chevrolet C10 "Pearl71" 1971 Brazilian style C10 1967 Chevrolet C10 Truck "Cloud9" C10 HISTORY AIR SUSPENSION Truck Frame Notches TYPES OF BODY DROP Patina Chevrolet Trucks The OKC Farm Truck Lambrecht Chevrolet Dealership C10 TRUCKS FOR SALE 1981 Chevrolet C-10 1972 Chevrolet C-10 s C10 Truck Racing crash FS 1960 Chevrolet C-10 FS 1972 Chevrolet C-10 Fs 1971 Chevrolet C-10 Fs 1970 Chevrolet C-10 Huge 1986 Chevy C10 4x4 NEW 1960 Chevrolet Apache Farmtruck Towing a Boat vs Twin Turbo Porsche Truck loading FAIL!! SOLID C10 Epic Chevy Truck Jump Fail What does 1000HP look like?  F 1967 Chevrolet C-10 Chevy Apache Twin Turbos F 1984 Chevrolet C10 What 3200HP of NOS Looks Like F 1972 Chevrolet C-10 1972 C-10 Texas Reaper  f 1978 Chevrolet C-10 2500 HP 632CI BBC chevy engine 1972 c10 SEMA ratrod F 1970 Chevrolet C-10 Full Size Chevy Jump Fail 1965 Chevrolet C-10 The Fastest Truck in the World f 1985 Chevrolet C-10 Stepside 1971 Chevrolet C-10 SHORT WHEEL BASE f. 1972 Chevrolet C-10 f. 1972 Chevrolet C-10 Ford Raptor Truck Jump Fail f 1981 Chevrolet C10 1971. Chevrolet C-10 Truck Jump and crash fail  A 1967 Chevrolet C-10 1971 Chevrolet C-10 1965 Chevrolet C-10  HOMECUTT 87 C10 chevy truck Arguing with a hater while Dragging my c10  Trent Eschete's '87 Chevy C10 Monster Truck Crashes Into Spectators Jerrys Jet Truck Full Video
