1960 C10Trucks cooling fan - C10Trucks.com
C10Trucks.com
It shows that you are unregistered, or not logged in to The Forum. Please register with us by clicking Here
Click here to Join C10Trucks , Membership is Totally Free
How to make your first post on C10trucks.com Click Here.
Go Back   C10Trucks.com > Topics of Interest > Cooling Systems, Radiators, Fans / A/C
Cooling Systems, Radiators, Fans / A/C Cooling Systems, Radiators, Fans / A/C
Click here for C10 Truck Parts for sale on ebay
Reply
Thread Tools Display Modes
  #1
Old 10-06-2018, 11:25 PM
JMitchell1400's Avatar
JMitchell1400 JMitchell1400 is offline
Junior Member
Default 1960 C10Trucks cooling fan
I have a 1960 C10 stepside with a 283 that may have been bored (block was decked). I’m running hot at idle (230ish) but good at road speed. Replaced thermostat and coolant. It has what I believe is the original radiator (Harrison) and original huge fan shroud but no mechanical fan and a single electric fan zip tied through the radiator right up against it. Does it need the shroud with an electric fan and any thoughts on if fan against radiator could be air flow problem causing it to run hot at idle? Also, right in front of radiator is what appears to be an old transmission cooler that isn’t connected to anything so I pulled it out to get more air to radiator. There’s a new trans cooler zip tied in front of it. Did these 1960s come with cooler? Thanks!
4494
Sponsored Links
Advertisement
  #2
Old 10-06-2018, 11:34 PM
406Rich's Avatar
406Rich 406Rich is offline
Default
Was your truck originally a V8..? V8`s used a larger radiator than the 6 cylinder models that is the first question, next if you have the original shroud used a clutch style five blade fan..also too much (advance ) timing will have a big factor on an engine to run hot. gives us a little more on your ignition.
__________________
`37 Ford Coupe, 406/350/324 posi
`64 C10, 350/350/373 posi
`68 Dodge Dart 370/904/325 sure grip
`69 Camaro RS/SS 350/350/307
"The difference between stupidity and genius is genius has its limits"...Albert Einstein
“Life is not a journey to the grave with the intention of arriving safely in one pretty and well preserved piece, but to skid across the line broadside, thoroughly used up, worn out, leaking oil, shouting GERONIMO!”
106
  #3
Old 10-06-2018, 11:39 PM
Junior Member
Default
I don’t know what it originally had but the block casting # matches a 1960-1962 283. Was thinking about replacing with a new radiatior. Any suggestions? They are. To be hard to find. It has a standard ignition but vacuum line on distributor isn’t connected to either outlet on carb
4494
  #4
Old 10-06-2018, 11:54 PM
406Rich's Avatar
Default
For a new radiator use the Champion here, 3 row
https://www.championradiators.com/Ch...ator-1960-1962 I as well as many others have with no issues, as said use a clutch style five blade fan, shroud and start using your vacuum advance connected to manifold vacuum port. any others block off.
__________________
106
  #5
Old 10-06-2018, 11:56 PM
Junior Member
Default
Thanks I’ll start with distributor vacuum and check out that radiator!
4494
  #6
Old 10-06-2018, 11:59 PM
406Rich's Avatar
Default
You`ll end up retiming your engine, first suck on the end off the vacuum hose, hold the vacuum with your tongue for about ten seconds, if its still holding vacuum its good, if it leaks down replace the vacuum dashpot, in the event it does turn out good leave disconnected from the vacuum source, but block off the vacuum source, set timing, then reconnect the dashpot..
__________________
106
  #7
Old 10-07-2018, 11:45 AM
Junior Member
Default
Still learning here...is the dash pot the funnel looking part the vac line connects to on distributor?
4494
  #8
Old 10-07-2018, 02:32 PM
Junior Member
Default
If I replace with a champion do you recommend the overflow tank or is it necessary?
4494
  #9
Old 10-07-2018, 08:47 PM
406Rich's Avatar
Default
I had one although it never kicked any coolant out after the system was full...probably not a bad idea....! Here`s some info on correct overflow height..
https://www.hotrodhotline.com/md/html/fan_control.php
__________________
106
  #10
Old 10-10-2018, 07:18 PM
Poynor Real Estate Team Poynor Real Estate Team is offline
Junior Member
Default Help lower water temperature
Have you tried running some of AMSOIL’s anti freeze boost? May want to completely switch all lubricants over. AMSOIL has lowered my oil temp and water temp.
www.PoynorsMotorSupplies.com
AMSOIL Dominator Coolant Boost
__________________
Kelly Poynor
(509) 554-3856
Poynor's Motor Supplies
3700
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertisement
Partner Links
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
c10 trucks 67 72 c10 trucks c10 trucks for sale classic c10 trucks chevy c10 trucks used c10 trucks bagged c10 trucks slammed c10 trucks 1960 Chevy C10 Truck 1961 Chevy C10 Truck 1962 Chevy C10 Truck 1963 Chevy C10 Truck 1964 Chevy C10 Truck 1965 Chevy C10 Truck 1966 Chevy C10 Truck 1967 Chevy C10 Truck 1968 Chevy C10 Truck 1969 Chevy C10 Truck 1970 Chevy C10 Truck 1971 Chevy C10 Truck 1972 Chevy C10 Truck 1973 Chevy C10 Truck 1974 Chevy C10 Truck 1975 Chevy C10 Truck 1976 Chevy C10 Truck 1977 Chevy C10 Truck 1978 Chevy C10 Truck 1979 Chevy C10 Truck 1980 Chevy C10 Truck 1981 Chevy C10 Truck 1982 Chevy C10 Truck 1983 Chevy C10 Truck 1984 Chevy C10 Truck 1985 Chevy C10 Truck 1986 Chevy C10 Truck 1987 Chevy C10 Truck 1988 Chevy C10 Truck 1989 Chevy C10 Truck 1990 Chevy C10 Truck 1991 Chevy C10 Truck 1992 Chevy C10 Truck 1993 Chevy C10 Truck 1994 Chevy C10 Truck 1995 Chevy C10 Truck 1996 Chevy C10 Truck 1997 Chevy C10 Truck 1998 Chevy C10 Truck 1999 Chevy C10 Truck 2000 Chevy C10 Truck 2001 Chevy C10 Truck 1950 Chevrolet Truck 1968 C10 SNAKEBIT V-10 Hazel 1967 Chevrolet C10 BUILD 1968 C10 Chevrolet C10 Truck "5150" Plane Engine 68 c10 DINOS 1964 Chevrolet C10 DUALLY 1971 Chevrolet C10 "Pearl71" 1971 Brazilian style C10 1967 Chevrolet C10 Truck "Cloud9" C10 HISTORY AIR SUSPENSION Truck Frame Notches TYPES OF BODY DROP Patina Chevrolet Trucks The OKC Farm Truck Lambrecht Chevrolet Dealership C10 TRUCKS FOR SALE 1981 Chevrolet C-10 1972 Chevrolet C-10 s C10 Truck Racing crash FS 1960 Chevrolet C-10 FS 1972 Chevrolet C-10 Fs 1971 Chevrolet C-10 Fs 1970 Chevrolet C-10 Huge 1986 Chevy C10 4x4 NEW 1960 Chevrolet Apache Farmtruck Towing a Boat vs Twin Turbo Porsche Truck loading FAIL!! SOLID C10 Epic Chevy Truck Jump Fail What does 1000HP look like?  F 1967 Chevrolet C-10 Chevy Apache Twin Turbos F 1984 Chevrolet C10 What 3200HP of NOS Looks Like F 1972 Chevrolet C-10 1972 C-10 Texas Reaper  f 1978 Chevrolet C-10 2500 HP 632CI BBC chevy engine 1972 c10 SEMA ratrod F 1970 Chevrolet C-10 Full Size Chevy Jump Fail 1965 Chevrolet C-10 The Fastest Truck in the World f 1985 Chevrolet C-10 Stepside 1971 Chevrolet C-10 SHORT WHEEL BASE f. 1972 Chevrolet C-10 f. 1972 Chevrolet C-10 Ford Raptor Truck Jump Fail f 1981 Chevrolet C10 1971. Chevrolet C-10 Truck Jump and crash fail  A 1967 Chevrolet C-10 1971 Chevrolet C-10 1965 Chevrolet C-10  HOMECUTT 87 C10 chevy truck Arguing with a hater while Dragging my c10  Trent Eschete's '87 Chevy C10 Monster Truck Crashes Into Spectators Jerrys Jet Truck Full Video
