Carb adapter/Choke hook up - C10Trucks.com
C10Trucks.com
It shows that you are unregistered, or not logged in to The Forum. Please register with us by clicking Here
Click here to Join C10Trucks , Membership is Totally Free
How to make your first post on C10trucks.com Click Here.
Go Back   C10Trucks.com > Topics of Interest > Fuel Systems, Fuel Injection, Carburation, Supercharging
Fuel Systems, Fuel Injection, Carburation, Supercharging Fuel Systems, Fuel Injection, Carburation, Supercharging
Click here for C10 Truck Parts for sale on ebay
Reply
Thread Tools Display Modes
  #1
Old 11-10-2017, 07:09 PM
robbo robbo is offline
Member
Default Carb adapter/Choke hook up
Ok, so I have a problem, I went to install my carb, a rochester and noticed that the intake on my crate engine is a square bore, my rochester is a spread bore, what are your opinions, switch intakes to a spread bore or use an adapter, also I have a carb with a divorced choke so I am not sure how to hook up the choke or if I even can on this intake, I purchased an electric one but still not sure. If I switch intakes I was going to go with the edelbrock one, do they make one that will accept a divorced choke, I was thinking of the performer 2101, it says it will accept a late model choke, but I think that is a carb with the choke attached? What are your opinions? Thanks.
1369
Sponsored Links
Advertisement
  #2
Old 11-11-2017, 12:22 AM
406Rich's Avatar
406Rich 406Rich is offline
Default
Quote:
If you want the quadrajet carb buy the right intake, there is no way of hooking up a divorced choke to it period, been there done that..if you want that current intake you`ll need the correct edelbrock carb with an electric choke or a square bore holley with electric choke.
Electric choke lot less troublesome..buy a used holley or eldebrock with an electric choke off craigslist put a kit into it.
__________________
`37 Ford Coupe, 406/350/324 posi
`64 C10, 350/350/373 posi
`68 Dodge Dart 370/904/325 sure grip
`69 Camaro RS/SS 350/350/307
"The difference between stupidity and genius is genius has its limits"...Albert Einstein
“Life is not a journey to the grave with the intention of arriving safely in one pretty and well preserved piece, but to skid across the line broadside, thoroughly used up, worn out, leaking oil, shouting GERONIMO!”
106
  #3
Old 11-11-2017, 05:12 PM
Member
Default
Yeah, I like my rochester, and I spent some coin getting it rebuilt and tuned, I did a little more research and it looks like the performer 2101 will work with my divorced choke. I believe that I can adapt the electric choke to work off of that correct?
1369
  #4
Old 11-11-2017, 09:02 PM
406Rich's Avatar
Default
2101 is the correct intake for the Electric choke ( divorced choke is the one that has the thermal spring in the intake that gets heated by engine temp ) so with the electric choke you just need to run a wire from the choke to the fuse box, tie into the one that is marked ( switched ) its on the left side of the fuse box..then its just a matter adjusting the choke dial as needed. use a rubber grommet when you run you wire thru the fire wall and use a 10 amp in line fuse.
__________________
106
  #5
Old 11-12-2017, 08:49 AM
Member
Default
Cool, thanks for the tip.
1369
  #6
Old 11-12-2017, 10:23 AM
406Rich's Avatar
Default
Before you hook up the electrical to the switched post on the fuse block, use a lighted test lead to confirm that it is switched on/off by the ignition switch.
__________________
106
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertisement
Partner Links
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
c10 trucks 67 72 c10 trucks c10 trucks for sale classic c10 trucks chevy c10 trucks used c10 trucks bagged c10 trucks slammed c10 trucks 1960 Chevy C10 Truck 1961 Chevy C10 Truck 1962 Chevy C10 Truck 1963 Chevy C10 Truck 1964 Chevy C10 Truck 1965 Chevy C10 Truck 1966 Chevy C10 Truck 1967 Chevy C10 Truck 1968 Chevy C10 Truck 1969 Chevy C10 Truck 1970 Chevy C10 Truck 1971 Chevy C10 Truck 1972 Chevy C10 Truck 1973 Chevy C10 Truck 1974 Chevy C10 Truck 1975 Chevy C10 Truck 1976 Chevy C10 Truck 1977 Chevy C10 Truck 1978 Chevy C10 Truck 1979 Chevy C10 Truck 1980 Chevy C10 Truck 1981 Chevy C10 Truck 1982 Chevy C10 Truck 1983 Chevy C10 Truck 1984 Chevy C10 Truck 1985 Chevy C10 Truck 1986 Chevy C10 Truck 1987 Chevy C10 Truck 1988 Chevy C10 Truck 1989 Chevy C10 Truck 1990 Chevy C10 Truck 1991 Chevy C10 Truck 1992 Chevy C10 Truck 1993 Chevy C10 Truck 1994 Chevy C10 Truck 1995 Chevy C10 Truck 1996 Chevy C10 Truck 1997 Chevy C10 Truck 1998 Chevy C10 Truck 1999 Chevy C10 Truck 2000 Chevy C10 Truck 2001 Chevy C10 Truck 1950 Chevrolet Truck 1968 C10 SNAKEBIT V-10 Hazel 1967 Chevrolet C10 BUILD 1968 C10 Chevrolet C10 Truck "5150" Plane Engine 68 c10 DINOS 1964 Chevrolet C10 DUALLY 1971 Chevrolet C10 "Pearl71" 1971 Brazilian style C10 1967 Chevrolet C10 Truck "Cloud9" C10 HISTORY AIR SUSPENSION Truck Frame Notches TYPES OF BODY DROP Patina Chevrolet Trucks The OKC Farm Truck Lambrecht Chevrolet Dealership C10 TRUCKS FOR SALE 1981 Chevrolet C-10 1972 Chevrolet C-10 s C10 Truck Racing crash FS 1960 Chevrolet C-10 FS 1972 Chevrolet C-10 Fs 1971 Chevrolet C-10 Fs 1970 Chevrolet C-10 Huge 1986 Chevy C10 4x4 NEW 1960 Chevrolet Apache Farmtruck Towing a Boat vs Twin Turbo Porsche Truck loading FAIL!! SOLID C10 Epic Chevy Truck Jump Fail What does 1000HP look like?  F 1967 Chevrolet C-10 Chevy Apache Twin Turbos F 1984 Chevrolet C10 What 3200HP of NOS Looks Like F 1972 Chevrolet C-10 1972 C-10 Texas Reaper  f 1978 Chevrolet C-10 2500 HP 632CI BBC chevy engine 1972 c10 SEMA ratrod F 1970 Chevrolet C-10 Full Size Chevy Jump Fail 1965 Chevrolet C-10 The Fastest Truck in the World f 1985 Chevrolet C-10 Stepside 1971 Chevrolet C-10 SHORT WHEEL BASE f. 1972 Chevrolet C-10 f. 1972 Chevrolet C-10 Ford Raptor Truck Jump Fail f 1981 Chevrolet C10 1971. Chevrolet C-10 Truck Jump and crash fail  A 1967 Chevrolet C-10 1971 Chevrolet C-10 1965 Chevrolet C-10  HOMECUTT 87 C10 chevy truck Arguing with a hater while Dragging my c10  Trent Eschete's '87 Chevy C10 Monster Truck Crashes Into Spectators Jerrys Jet Truck Full Video
