My '61 GMC - C10Trucks.com
C10Trucks.com
It shows that you are unregistered, or not logged in to The Forum. Please register with us by clicking Here
Click here to Join C10Trucks , Membership is Totally Free
How to make your first post on C10trucks.com Click Here.
Go Back   C10Trucks.com > 1st - 2nd and 3rd & 4th Generation Chevy C10 Trucks > GMC Trucks
GMC Trucks GMC Trucks
Click here for C10 Truck Parts for sale on ebay
Reply
Thread Tools Display Modes
  #1
Old 08-23-2015, 06:45 AM
Dusty's Avatar
Dusty Dusty is offline
Junior Member
Default My '61 GMC
Basic spec; 350/350, torsion bar front suspension (I guess that this is common to the GMCs) and coil springs with air shocks (dampers not bags) on the rear.
1516
Sponsored Links
Advertisement
  #2
Old 08-23-2015, 06:49 AM
ProMetalShop's Avatar
ProMetalShop ProMetalShop is offline
Administrator & Sheet Metal Junkie
Default
How nice is that, that color is just right for your GMC ! !
__________________
Thanks Steve
https://www.facebook.com/Prometalshop?ref=hl
http://prometalshop.com/
Hot Rod Sheet Metal Fabrication and Shaping Shop.
http://i5.photobucket.com/albums/y17...ps949483d5.jpg
8
  #3
Old 08-23-2015, 06:54 AM
Dusty's Avatar
Junior Member
Default
Thanks, a little tempted to paint it to match my wife's race car and tow buggy...
1516
  #4
Old 08-23-2015, 07:00 AM
Default
That would certainly let spectators know it's part of the pack.....
__________________
Thanks Steve
8
  #5
Old 08-23-2015, 07:03 AM
Dusty's Avatar
Junior Member
Default
Quote:
True enough but I agree with you that the orange suits it. So many over here have "patina" which isn't my thing.
1516
  #6
Old 08-23-2015, 09:07 AM
406Rich's Avatar
406Rich 406Rich is offline
Default
Dusty, I too like the orange and am not a fan of patina, as far as your torsion bar suspension both GMC and Chevy used it from 1960 to `62, they both changed to coils in the front in `63.
__________________
`37 Ford Coupe, 406/350/324 posi
`64 C10, 350/350/373 posi
`68 Dodge Dart 370/904/325 sure grip
`69 Camaro RS/SS 350/350/307
"The difference between stupidity and genius is genius has its limits"...Albert Einstein
“Life is not a journey to the grave with the intention of arriving safely in one pretty and well preserved piece, but to skid across the line broadside, thoroughly used up, worn out, leaking oil, shouting GERONIMO!”
106
  #7
Old 08-23-2015, 12:27 PM
Dusty's Avatar
Junior Member
Default
Quote:
I have had a quick look at lowering the front suspension but the pitman arm looks to be quite close to the crossmember. Is there a cranked arm available to solve this without screwing up the geometry?
__________________
1961 GMC fleetside long bed 350/350
1930 Model A hot rod coupe 383/350
1948 Austin 16 hot rod sedan V6 manual
Crew chief; wife's alky burning blown 572 BBC Corvette
1516
  #8
Old 08-23-2015, 07:48 PM
lakeroadster's Avatar
lakeroadster lakeroadster is offline
Senior Member
Default
Nice truck Rusty, and nice 'vette too!
Is that your fenderless hot rod in your avatar? If so please share some photo's of that with us also.
_____
John
112
  #9
Old 08-24-2015, 01:54 AM
406Rich's Avatar
Default
Something to keep in mind, when you crank the bars down, you will be decreasing the spring rate, while this may make the ride softer, it will also decrease the springs ability to carry a load. This could end up giving you poor handling characteristics, potential for bottoming out easily and increased tire wear. I would estimate you could probably go 2 inches of drop before you see any issues. You'll also need to get it realigned, as any ride height change will change camber, caster, and toe. Also be aware, most alignment shops will not guarantee alignments of vehicles with altered suspensions. Theoretically they should be done on the ground so you can see how far the truck drops for a specific turn of the bolts. Practically speaking, doing the adjustment when the suspension is "unloaded" is much less likely to strip the adjuster bolts. If you have access to a lift, you could unwind one turn, drop the truck, raise it back up and do another turn, etc until you're happy with the drop. The same thing could be done with a floor jack and stands, but it would be a lot more work. If you decide to fool with them, take this advice, use and let soak a good pentrating fluid, such as Kroll Oil or PB Blaster. put on a good amount, let soak overnight, apply it again, let soak over night once more, then SLOWLY turn the Big Nut BOTH ways for a little bit. Because if you break the special nut or strip that bolt you're in for a real treat to replace. They also sell drop spindles for the 60 to 62 trucks now thru CPP one of the Vendors on the site..this may be a better option for you as well…
http://www.classicperform.com/Chevy-Truck.htm#5
__________________
106
  #10
Old 08-24-2015, 02:06 AM
Dusty's Avatar
Junior Member
Default
Thanks Rich.
I prefer the dropped spindles to preserve the geometry. The front end is rather bouncy which I thought might have been tired dampers but perhaps it is already lowered a bit on the bars.
I shall get the alignment checked to eliminate that as a problem. The front wheels seem to have a fair amount of offset so I may change them as I don't like them much.
__________________
1516
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertisement
Partner Links
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
c10 trucks 67 72 c10 trucks c10 trucks for sale classic c10 trucks chevy c10 trucks used c10 trucks bagged c10 trucks slammed c10 trucks 1960 Chevy C10 Truck 1961 Chevy C10 Truck 1962 Chevy C10 Truck 1963 Chevy C10 Truck 1964 Chevy C10 Truck 1965 Chevy C10 Truck 1966 Chevy C10 Truck 1967 Chevy C10 Truck 1968 Chevy C10 Truck 1969 Chevy C10 Truck 1970 Chevy C10 Truck 1971 Chevy C10 Truck 1972 Chevy C10 Truck 1973 Chevy C10 Truck 1974 Chevy C10 Truck 1975 Chevy C10 Truck 1976 Chevy C10 Truck 1977 Chevy C10 Truck 1978 Chevy C10 Truck 1979 Chevy C10 Truck 1980 Chevy C10 Truck 1981 Chevy C10 Truck 1982 Chevy C10 Truck 1983 Chevy C10 Truck 1984 Chevy C10 Truck 1985 Chevy C10 Truck 1986 Chevy C10 Truck 1987 Chevy C10 Truck 1988 Chevy C10 Truck 1989 Chevy C10 Truck 1990 Chevy C10 Truck 1991 Chevy C10 Truck 1992 Chevy C10 Truck 1993 Chevy C10 Truck 1994 Chevy C10 Truck 1995 Chevy C10 Truck 1996 Chevy C10 Truck 1997 Chevy C10 Truck 1998 Chevy C10 Truck 1999 Chevy C10 Truck 2000 Chevy C10 Truck 2001 Chevy C10 Truck 1950 Chevrolet Truck 1968 C10 SNAKEBIT V-10 Hazel 1967 Chevrolet C10 BUILD 1968 C10 Chevrolet C10 Truck "5150" Plane Engine 68 c10 DINOS 1964 Chevrolet C10 DUALLY 1971 Chevrolet C10 "Pearl71" 1971 Brazilian style C10 1967 Chevrolet C10 Truck "Cloud9" C10 HISTORY AIR SUSPENSION Truck Frame Notches TYPES OF BODY DROP Patina Chevrolet Trucks The OKC Farm Truck Lambrecht Chevrolet Dealership C10 TRUCKS FOR SALE 1981 Chevrolet C-10 1972 Chevrolet C-10 s C10 Truck Racing crash FS 1960 Chevrolet C-10 FS 1972 Chevrolet C-10 Fs 1971 Chevrolet C-10 Fs 1970 Chevrolet C-10 Huge 1986 Chevy C10 4x4 NEW 1960 Chevrolet Apache Farmtruck Towing a Boat vs Twin Turbo Porsche Truck loading FAIL!! SOLID C10 Epic Chevy Truck Jump Fail What does 1000HP look like?  F 1967 Chevrolet C-10 Chevy Apache Twin Turbos F 1984 Chevrolet C10 What 3200HP of NOS Looks Like F 1972 Chevrolet C-10 1972 C-10 Texas Reaper  f 1978 Chevrolet C-10 2500 HP 632CI BBC chevy engine 1972 c10 SEMA ratrod F 1970 Chevrolet C-10 Full Size Chevy Jump Fail 1965 Chevrolet C-10 The Fastest Truck in the World f 1985 Chevrolet C-10 Stepside 1971 Chevrolet C-10 SHORT WHEEL BASE f. 1972 Chevrolet C-10 f. 1972 Chevrolet C-10 Ford Raptor Truck Jump Fail f 1981 Chevrolet C10 1971. Chevrolet C-10 Truck Jump and crash fail  A 1967 Chevrolet C-10 1971 Chevrolet C-10 1965 Chevrolet C-10  HOMECUTT 87 C10 chevy truck Arguing with a hater while Dragging my c10  Trent Eschete's '87 Chevy C10 Monster Truck Crashes Into Spectators Jerrys Jet Truck Full Video
