Profile Dies - C10Trucks.com
Go Back   C10Trucks.com > Metal Fabrication & Repair Questions > Metal Fabrication & Repair Questions
Metal Fabrication & Repair Questions Metal Fabrication & Repair Questions
Old 09-29-2013, 08:58 PM
ProMetalShop's Avatar
ProMetalShop ProMetalShop is offline
Administrator & Sheet Metal Junkie
Default Profile Dies
Had some time tonight, so I cut some profile dies, and had a chance to try them out.
I used 3/8 6061 for the dies. I cut them out with the plasma cutter and dressed them up in the mill, and gave them a light polish with 100 grit.
I made a quick follow template out of 18 gauge and tacked a washer to it for the reveal.
Here's the template.
Here's some samples I ran. This one is a short on and pretty straight.
This one I coppied the shape of the cowl and door area on the Chevy.
I got the panel to shape as I was pulling it threw the die and pressed down at the same time. In between wheeling the outer edge so the panel would follow easier.
This next panel is 36 inches long. Now it got real ugly and out of hand. I actually put it on the floor and step on it to get it back in shape. Most times a panel wants to relax as its coming out of the die and bend towards the floor, but this one bent up as the die stretched the center of the reveal, almost as if a reverse curve.
So this time I changed the dies around, and it did the same thing. It curved it self in the opposite direction I wanted it to go.
So finally I figured I should have prestretch the panel. Now the die beat the panel up a bit, so I figured I would try to stretch the inside of the reveal and if that worked I would dress the damage frame the die, or my lack of control over the panel and die.
Panel before stretch, notice the reverse in the panel.
This is after stretch, and also have to mention quite a bit of wheeling on the outer sides to distress the panel, and clean up the damage from me stepping on it.
You can see some light witness lines from the edge of the dies, but those will go away as I finish the panel tomorrow.
Thanks for looking
Thanks Steve
https://www.facebook.com/Prometalshop?ref=hl
http://prometalshop.com/
Hot Rod Sheet Metal Fabrication and Shaping Shop.
http://i5.photobucket.com/albums/y17...ps949483d5.jpg
8
Old 10-04-2013, 09:44 PM
406Rich's Avatar
406Rich 406Rich is offline
Administrator
Way cool Steve, are these for the doors on the 34/35 chevy.....?
`37 Ford Coupe, 406/350/324 posi
`64 C10, 350/350/373 posi
`68 Dodge Dart 370/904/325 sure grip
`69 Camaro RS/SS 350/350/307
"The difference between stupidity and genius is genius has its limits"...Albert Einstein
“Life is not a journey to the grave with the intention of arriving safely in one pretty and well preserved piece, but to skid across the line broadside, thoroughly used up, worn out, leaking oil, shouting GERONIMO!”
106
Old 10-04-2013, 11:09 PM
Thanks Rich, these are dies I made up for a body I'm going to build here in the next year. It's a bit larger body line then the 34 Chevy. I'm looking to build a one off truck body with an extended cab. I've been making templates for my door jams and made other dies to aid me in shaping the cowl. All I need now is time.....
Thanks Steve
8
Old 10-05-2013, 02:49 PM
406Rich's Avatar
Administrator
Had a friend with a 34 chevy pu, and you`re right no leg room....but plenty of room under the hood on them...
106
Old 10-06-2013, 08:05 AM
This truck will not be a copy of any of the big three, just my interpretation of what a 1930's or 40's truck would look like.
Thanks Steve
8
Old 10-20-2013, 11:29 AM
cfjfisher cfjfisher is offline
great thread Steve. Metal forming is not as easy as you make it look. Keep up the good work and I'll sit back and watch
4716
  #7
Old 10-20-2013, 12:24 PM
406Rich's Avatar
Administrator
Quote:
Boy ain`t that the truth, most of mine look like an accident from the freeway....
106
  #8
Old 10-23-2013, 08:44 AM
Thanks guys
Thanks Steve
8
  #9
Old 10-28-2013, 04:17 PM
OK Steve don't stop now.
4716
  #10
Old 10-28-2013, 09:32 PM
I will be creating more tooling around here soon. I'm rounding up my winter work, and my stuff will come when I have that under controll.
Right now I started the chassis for a pedal car I'm building for a fellow out mid west. It's proving to be a very cool build.
Thanks Steve
8
c10 trucks 67 72 c10 trucks c10 trucks for sale classic c10 trucks chevy c10 trucks used c10 trucks bagged c10 trucks slammed c10 trucks 1960 Chevy C10 Truck 1961 Chevy C10 Truck 1962 Chevy C10 Truck 1963 Chevy C10 Truck 1964 Chevy C10 Truck 1965 Chevy C10 Truck 1966 Chevy C10 Truck 1967 Chevy C10 Truck 1968 Chevy C10 Truck 1969 Chevy C10 Truck 1970 Chevy C10 Truck 1971 Chevy C10 Truck 1972 Chevy C10 Truck 1973 Chevy C10 Truck 1974 Chevy C10 Truck 1975 Chevy C10 Truck 1976 Chevy C10 Truck 1977 Chevy C10 Truck 1978 Chevy C10 Truck 1979 Chevy C10 Truck 1980 Chevy C10 Truck 1981 Chevy C10 Truck 1982 Chevy C10 Truck 1983 Chevy C10 Truck 1984 Chevy C10 Truck 1985 Chevy C10 Truck 1986 Chevy C10 Truck 1987 Chevy C10 Truck 1988 Chevy C10 Truck 1989 Chevy C10 Truck 1990 Chevy C10 Truck 1991 Chevy C10 Truck 1992 Chevy C10 Truck 1993 Chevy C10 Truck 1994 Chevy C10 Truck 1995 Chevy C10 Truck 1996 Chevy C10 Truck 1997 Chevy C10 Truck 1998 Chevy C10 Truck 1999 Chevy C10 Truck 2000 Chevy C10 Truck 2001 Chevy C10 Truck 1950 Chevrolet Truck 1968 C10 SNAKEBIT V-10 Hazel 1967 Chevrolet C10 BUILD 1968 C10 Chevrolet C10 Truck "5150" Plane Engine 68 c10 DINOS 1964 Chevrolet C10 DUALLY 1971 Chevrolet C10 "Pearl71" 1971 Brazilian style C10 1967 Chevrolet C10 Truck "Cloud9" C10 HISTORY AIR SUSPENSION Truck Frame Notches TYPES OF BODY DROP Patina Chevrolet Trucks The OKC Farm Truck Lambrecht Chevrolet Dealership C10 TRUCKS FOR SALE 1981 Chevrolet C-10 1972 Chevrolet C-10 s C10 Truck Racing crash FS 1960 Chevrolet C-10 FS 1972 Chevrolet C-10 Fs 1971 Chevrolet C-10 Fs 1970 Chevrolet C-10 Huge 1986 Chevy C10 4x4 NEW 1960 Chevrolet Apache Farmtruck Towing a Boat vs Twin Turbo Porsche Truck loading FAIL!! SOLID C10 Epic Chevy Truck Jump Fail What does 1000HP look like?  F 1967 Chevrolet C-10 Chevy Apache Twin Turbos F 1984 Chevrolet C10 What 3200HP of NOS Looks Like F 1972 Chevrolet C-10 1972 C-10 Texas Reaper  f 1978 Chevrolet C-10 2500 HP 632CI BBC chevy engine 1972 c10 SEMA ratrod F 1970 Chevrolet C-10 Full Size Chevy Jump Fail 1965 Chevrolet C-10 The Fastest Truck in the World f 1985 Chevrolet C-10 Stepside 1971 Chevrolet C-10 SHORT WHEEL BASE f. 1972 Chevrolet C-10 f. 1972 Chevrolet C-10 Ford Raptor Truck Jump Fail f 1981 Chevrolet C10 1971. Chevrolet C-10 Truck Jump and crash fail  A 1967 Chevrolet C-10 1971 Chevrolet C-10 1965 Chevrolet C-10  HOMECUTT 87 C10 chevy truck Arguing with a hater while Dragging my c10  Trent Eschete's '87 Chevy C10 Monster Truck Crashes Into Spectators Jerrys Jet Truck Full Video
