homebuilt custom fuel tank - C10Trucks.com
Go Back   C10Trucks.com > Metal Fabrication & Repair Questions > Metal Fabrication & Repair Questions
Metal Fabrication & Repair Questions Metal Fabrication & Repair Questions
Old 11-09-2014, 07:55 PM
sharpmark's Avatar
sharpmark sharpmark is offline
Member
Default homebuilt custom fuel tank
heres my take on a custom fuel tank for the rear of my 69 short stepside.
measured how big I could go to fill the space in between the chassis rails and behind the diff and offset cross member.cut the large piece out -basically the top/bottom and end pieces and got three folds put in it by a sheetmetal place.
as you can see - theres all that free area at the back
861
Old 11-09-2014, 08:05 PM
sharpmark's Avatar
Member
to protect the tank and also give me a towing option - I made up a towing hitch to bolt to the rear chassis rails.
this next photo shows how it sits in the chassis - I forgot to take some photos along the way
the round hole in the middle is cut out of the old behind the seat tank so I can use the sender and fuel pickup.
the orange webbing is a cut up cargo strap.
861
Old 11-09-2014, 08:10 PM
sharpmark's Avatar
Member
this shows how I made up the filler pipe which uses a short piece of petrol resistant rubber to attatch to the filler tube coming out of the tank.its made from different fillers from the wrecking yard.
861
Old 11-09-2014, 08:14 PM
sharpmark's Avatar
Member
i decided i wanted the filler in the guard and not in the rear deck area.
used a door lap and surrounding sheetmetal for a wrecking yard japer.this also shows the original filler pipe
861
Old 11-09-2014, 08:22 PM
sharpmark's Avatar
Member
another shot of the finished door before paint and also the patch in the original filler location.
found some more photos of the process
the original pattern prior to bending.with the 2 end bits.
filled old tank with water prior to cutting out with air powered cutting disc - safety first - a fiery explosion would be fun!!!
861
Old 11-09-2014, 09:06 PM
cfjfisher cfjfisher is offline
Nice work it al takes time
4716
  #7
Old 11-09-2014, 09:13 PM
sharpmark's Avatar
Member
played around with the 69 sender unit trying to make it fit but ended up putting a new outlet pipe into it and welding the sender unit on to it and bending the float arm to suit.
tried it on the side first and then the top where it ended up going.
this is the finished one and you can also see the extra breather pipe I welded at the back of the tank so that I had no slowfilling problems or the tank trying to collapse in
this photo shows the little reservoir/sump underneath.
and the finished item.
861
c10 trucks 67 72 c10 trucks c10 trucks for sale classic c10 trucks chevy c10 trucks used c10 trucks bagged c10 trucks slammed c10 trucks 1960 Chevy C10 Truck 1961 Chevy C10 Truck 1962 Chevy C10 Truck 1963 Chevy C10 Truck 1964 Chevy C10 Truck 1965 Chevy C10 Truck 1966 Chevy C10 Truck 1967 Chevy C10 Truck 1968 Chevy C10 Truck 1969 Chevy C10 Truck 1970 Chevy C10 Truck 1971 Chevy C10 Truck 1972 Chevy C10 Truck 1973 Chevy C10 Truck 1974 Chevy C10 Truck 1975 Chevy C10 Truck 1976 Chevy C10 Truck 1977 Chevy C10 Truck 1978 Chevy C10 Truck 1979 Chevy C10 Truck 1980 Chevy C10 Truck 1981 Chevy C10 Truck 1982 Chevy C10 Truck 1983 Chevy C10 Truck 1984 Chevy C10 Truck 1985 Chevy C10 Truck 1986 Chevy C10 Truck 1987 Chevy C10 Truck 1988 Chevy C10 Truck 1989 Chevy C10 Truck 1990 Chevy C10 Truck 1991 Chevy C10 Truck 1992 Chevy C10 Truck 1993 Chevy C10 Truck 1994 Chevy C10 Truck 1995 Chevy C10 Truck 1996 Chevy C10 Truck 1997 Chevy C10 Truck 1998 Chevy C10 Truck 1999 Chevy C10 Truck 2000 Chevy C10 Truck 2001 Chevy C10 Truck 1950 Chevrolet Truck 1968 C10 SNAKEBIT V-10 Hazel 1967 Chevrolet C10 BUILD 1968 C10 Chevrolet C10 Truck "5150" Plane Engine 68 c10 DINOS 1964 Chevrolet C10 DUALLY 1971 Chevrolet C10 "Pearl71" 1971 Brazilian style C10 1967 Chevrolet C10 Truck "Cloud9" C10 HISTORY AIR SUSPENSION Truck Frame Notches TYPES OF BODY DROP Patina Chevrolet Trucks The OKC Farm Truck Lambrecht Chevrolet Dealership C10 TRUCKS FOR SALE 1981 Chevrolet C-10 1972 Chevrolet C-10 s C10 Truck Racing crash FS 1960 Chevrolet C-10 FS 1972 Chevrolet C-10 Fs 1971 Chevrolet C-10 Fs 1970 Chevrolet C-10 Huge 1986 Chevy C10 4x4 NEW 1960 Chevrolet Apache Farmtruck Towing a Boat vs Twin Turbo Porsche Truck loading FAIL!! SOLID C10 Epic Chevy Truck Jump Fail What does 1000HP look like?  F 1967 Chevrolet C-10 Chevy Apache Twin Turbos F 1984 Chevrolet C10 What 3200HP of NOS Looks Like F 1972 Chevrolet C-10 1972 C-10 Texas Reaper  f 1978 Chevrolet C-10 2500 HP 632CI BBC chevy engine 1972 c10 SEMA ratrod F 1970 Chevrolet C-10 Full Size Chevy Jump Fail 1965 Chevrolet C-10 The Fastest Truck in the World f 1985 Chevrolet C-10 Stepside 1971 Chevrolet C-10 SHORT WHEEL BASE f. 1972 Chevrolet C-10 f. 1972 Chevrolet C-10 Ford Raptor Truck Jump Fail f 1981 Chevrolet C10 1971. Chevrolet C-10 Truck Jump and crash fail  A 1967 Chevrolet C-10 1971 Chevrolet C-10 1965 Chevrolet C-10  HOMECUTT 87 C10 chevy truck Arguing with a hater while Dragging my c10  Trent Eschete's '87 Chevy C10 Monster Truck Crashes Into Spectators Jerrys Jet Truck Full Video
