A new Project for an old guy - C10Trucks.com
Go Back   C10Trucks.com > Topics of Interest > Suspension Questions Chassis, Brakes, Springs, Shocks, Swaybars, Tire, Rims Etc
Suspension Questions Chassis, Brakes, Springs, Shocks, Swaybars, Tire, Rims Etc Suspension Questions Chassis, Brakes, Springs, Shocks, Swaybars, Tire, Rims Etc
Old 01-05-2018, 05:19 PM
Cooter! Cooter! is offline
Default A new Project for an old guy
This is a pic of my 'Pops' '66 a few years back.
It was a Utah Forestry Service truck built by GM as a 4X4 and on a 3/4 ton frame right from the factory. Not the more common Naapco conversion. He bought it from the Ranger who used it and liked his service truck so much he bought it when he retired.
My Pops then dragged his girlfriend around camping in it in the 70's and 80's. They got married (for 40+ years now), had two very pretty daughters, and they all would go and off-road and camp in this truck for many years in the California desert.
It's a pretty neat truck! As I understand it, it's not a dealer 4X4 conversion. It looks to be an actual "factory" K truck. It is on a 3/4 ton frame, divorced t-case, and closed knuckle 10 bolt front axle.
During that time he took out the old 292 I-6, put in a 350, re-did the interior, swapped the SM420 for a SM465 out of a dumptruck, re-painted it with Imron (lol), and there it sat for the next 20 years
I've been very good friends with the whole family since the 90's, and consider him my dad He's mid-70's now and not in the best shape But getting better!
I am a capable mechanic, and very familiar with Chevys, so I took it upon myself to do this project for him. I need to undo some crazy old aircraft mechanic guy stuff and add some convenience things for him.
My goal is to make it pretty again and easy for him to drive around if he wishes, and do this poor awesome truck some justice!
The engine is in really good shape and runs very well. I have converted the Rochester 2jet to a Quadrajet and manifold (I know it's not a holley), and converted the old point distributor to an HEI, added a fan shroud and replaced the 'flex fan' with a factory fan and clutch which is MUCH quieter.
The 4 speed makes some gear noise in 2nd, but shifts and works well enough to leave it alone.
Awhile ago, I added a power booster and divorced master cylinder to the drum brakes and they work MUCH better but I still want to add disks in front.
I want to add power steering (conversion plate from 456chevytrucks, 605 saginaw box, P/s pump/hoses/brackets for the SBC). Ill need to set the caster back a few degrees (axle shims) and I'll need a smaller diameter steering wheel, hopefully I can find a stock looking wheel.
(Edit) On second thought a surplus D44 is a MUCH better choice for the complete disk brake, power steering, and 40 year updated ball joints, u-joints, axles, etc..
The bench seat is nice, but he had it done by a buddy who was a couch upholsterer, so its super comfy but way, way, too padded and domed up top. Needs to be form fit and thinned out about 8"!
I replaced the 35" tires in the pic with 33's and still need to fab up some little steps for the cab.
I'll add A/C (Vintage air)
Then send it to the body shop (same color) because theres some rust in the doors.
I'd like to chronicle the re-build on here and welcome any input you guys have!
3522
Old 01-05-2018, 05:43 PM
lakeroadster's Avatar
lakeroadster lakeroadster is offline
That's one sweet truck. Looking forward to following along.
112
Old 01-05-2018, 11:28 PM
406Rich's Avatar
406Rich 406Rich is offline
Administrator
Cooter great project, glad you have joined here, as far as the disc assembly for the closed knuckle is beyond me....will have to do some searching....when you do the power steering the frame will need to be reinforced with a plate, two wheel trucks get one plate on the out side, I have read on the 4x4`s that guys were placing two one inside and one outside to keep the frame rails from cracking..
`37 Ford Coupe, 406/350/324 posi
`64 C10, 350/350/373 posi
`68 Dodge Dart 370/904/325 sure grip
`69 Camaro RS/SS 350/350/307
"The difference between stupidity and genius is genius has its limits"...Albert Einstein
“Life is not a journey to the grave with the intention of arriving safely in one pretty and well preserved piece, but to skid across the line broadside, thoroughly used up, worn out, leaking oil, shouting GERONIMO!”
106
Old 01-06-2018, 09:30 AM
cfjfisher cfjfisher is offline
Great project and good for you taking it on for a friend To C10 Trucks and yes take pictures as you go along
4716
Old 01-06-2018, 09:55 AM
406Rich's Avatar
Administrator
Couple articles on Disc brake conversion for closed knuckle..might help...!
http://www.fourwheeler.com/how-to/tr...ke-conversion/
http://www.binderplanet.com/forums/i...-brakes.41115/
106
Old 01-07-2018, 07:56 PM
Thanks for the well wishes and links! The first article is too funny, I've been off-roading with Verne before, he's hilarious
Here's a pic from today:
I just hauled a fridge to a buddies house 50 miles away in it. She still gets thumbs up! The paint polishes out easily, but I won't bother.
It's got the 33" all-terrains and black steel wheels. Not sure if I'll keep the spare in the spare-spot, it blocks the side mirror a bit but I don't really want it in the bed to rot. Any ideas? Maybe mount a pulley thing under the bed?
I wanted to try and use the stock front axle for nostalgias sake, but I went ahead and committed to using the whole surplus Dana 44 I got. Just need to gear to 3.73 and maybe drop in a Lock-rite. Then everything is new under there
I'll need to plumb in a combo valve for the brakes too. Thanks 406, I'll do that with both plates....
3522
  #7
Old 01-11-2018, 08:33 PM
I could start another thread but.... A friend has a 65 with the big back window and both the front and rear are busted.
I can find the glass if I google it but do you guys have a favorite forum sponsor, or good business to deal with? I'd rather throw the $ at someone who supports us.
3522
  #8
Old 01-11-2018, 09:33 PM
406Rich's Avatar
Administrator
There`s Ecklers and or Classic industries, you can also get the glass thru Safelite....
106
  #9
Old 01-12-2018, 12:23 AM
Ya, I'm close enough to Classic Ind, to pick it up and I saw that they (and Ecklers) were sponsors. I'll go that route Thanks 406
Gotta keep these on the road!
3522
  #10
Old 07-13-2018, 11:47 PM
Got some parts:
eTW9Ygr0Qu6KYwdgwq6OlQ by Cooter!, on Flickr
sfYEmfTvSeK%J6qAY5yVzw by Cooter!, on FlickrnNqOwZxgRdKIps7PqlMCVw by Cooter!, on Flickr
then fun stuff happened:
BnMYupmLR125%bYwf99heQ by Cooter!, on Flickr
Out with the old...
X45dtbqkRAmcAmM9DFrRVQ by Cooter!, on Flickr
In with the new....
3522
c10 trucks 67 72 c10 trucks c10 trucks for sale classic c10 trucks chevy c10 trucks used c10 trucks bagged c10 trucks slammed c10 trucks 1960 Chevy C10 Truck 1961 Chevy C10 Truck 1962 Chevy C10 Truck 1963 Chevy C10 Truck 1964 Chevy C10 Truck 1965 Chevy C10 Truck 1966 Chevy C10 Truck 1967 Chevy C10 Truck 1968 Chevy C10 Truck 1969 Chevy C10 Truck 1970 Chevy C10 Truck 1971 Chevy C10 Truck 1972 Chevy C10 Truck 1973 Chevy C10 Truck 1974 Chevy C10 Truck 1975 Chevy C10 Truck 1976 Chevy C10 Truck 1977 Chevy C10 Truck 1978 Chevy C10 Truck 1979 Chevy C10 Truck 1980 Chevy C10 Truck 1981 Chevy C10 Truck 1982 Chevy C10 Truck 1983 Chevy C10 Truck 1984 Chevy C10 Truck 1985 Chevy C10 Truck 1986 Chevy C10 Truck 1987 Chevy C10 Truck 1988 Chevy C10 Truck 1989 Chevy C10 Truck 1990 Chevy C10 Truck 1991 Chevy C10 Truck 1992 Chevy C10 Truck 1993 Chevy C10 Truck 1994 Chevy C10 Truck 1995 Chevy C10 Truck 1996 Chevy C10 Truck 1997 Chevy C10 Truck 1998 Chevy C10 Truck 1999 Chevy C10 Truck 2000 Chevy C10 Truck 2001 Chevy C10 Truck 1950 Chevrolet Truck 1968 C10 SNAKEBIT V-10 Hazel 1967 Chevrolet C10 BUILD 1968 C10 Chevrolet C10 Truck "5150" Plane Engine 68 c10 DINOS 1964 Chevrolet C10 DUALLY 1971 Chevrolet C10 "Pearl71" 1971 Brazilian style C10 1967 Chevrolet C10 Truck "Cloud9" C10 HISTORY AIR SUSPENSION Truck Frame Notches TYPES OF BODY DROP Patina Chevrolet Trucks The OKC Farm Truck Lambrecht Chevrolet Dealership C10 TRUCKS FOR SALE 1981 Chevrolet C-10 1972 Chevrolet C-10 s C10 Truck Racing crash FS 1960 Chevrolet C-10 FS 1972 Chevrolet C-10 Fs 1971 Chevrolet C-10 Fs 1970 Chevrolet C-10 Huge 1986 Chevy C10 4x4 NEW 1960 Chevrolet Apache Farmtruck Towing a Boat vs Twin Turbo Porsche Truck loading FAIL!! SOLID C10 Epic Chevy Truck Jump Fail What does 1000HP look like?  F 1967 Chevrolet C-10 Chevy Apache Twin Turbos F 1984 Chevrolet C10 What 3200HP of NOS Looks Like F 1972 Chevrolet C-10 1972 C-10 Texas Reaper  f 1978 Chevrolet C-10 2500 HP 632CI BBC chevy engine 1972 c10 SEMA ratrod F 1970 Chevrolet C-10 Full Size Chevy Jump Fail 1965 Chevrolet C-10 The Fastest Truck in the World f 1985 Chevrolet C-10 Stepside 1971 Chevrolet C-10 SHORT WHEEL BASE f. 1972 Chevrolet C-10 f. 1972 Chevrolet C-10 Ford Raptor Truck Jump Fail f 1981 Chevrolet C10 1971. Chevrolet C-10 Truck Jump and crash fail  A 1967 Chevrolet C-10 1971 Chevrolet C-10 1965 Chevrolet C-10  HOMECUTT 87 C10 chevy truck Arguing with a hater while Dragging my c10  Trent Eschete's '87 Chevy C10 Monster Truck Crashes Into Spectators Jerrys Jet Truck Full Video
