New Member - C10Trucks.com
C10Trucks.com
It shows that you are unregistered, or not logged in to The Forum. Please register with us by clicking Here
Click here to Join C10Trucks , Membership is Totally Free
How to make your first post on C10trucks.com Click Here.
Go Back   C10Trucks.com > 1st - 2nd and 3rd & 4th Generation Chevy C10 Trucks > First generation 1960–1966 Chevy C10 Trucks
First generation 1960–1966 Chevy C10 Trucks First generation 1960–1966 Chevy C10 Trucks
Click here for C10 Truck Parts for sale on ebay
Reply
Thread Tools Display Modes
  #1
Old 09-16-2019, 12:07 PM
RoadTrip RoadTrip is online now
Junior Member
Default New Member
Hello from Alabama, I have recently begun a ground up restoration of a 1964 C10 and am changing/modernizing many things on it. Frame was blasted and powdercoated, now working on the front suspension. I bought the entire front suspension assembly from a 1984 1/2 ton truck and mounted it to the frame. I am now installing the steering linkage and am wondering if anyone else has done this? The idler arm from the 1984 truck will not match up (not even close) with any frame holes for the old idler arm. Does the original 64 style arm work with the 1984 drag link? Also installing power steering and have mounted the adapter kit on the left side of the frame but thinking that will be a simple bolt on procedure for the pitman arm. Is anyone aware of any potential problems I may see with this suspension change? Thanks!!
5478
Sponsored Links
Advertisement
  #2
Old 09-18-2019, 08:31 PM
mahto mahto is offline
Junior Member
Default suspension
I know you can use 82 idler arm not sure about power-steering the 66 frame is flat where the power box mounts, the CPP adapter spaces the box correctly off the frame. If you bolted the power box up without some sort of spacers, either the frame will crack or the box will break because of the bind.....no way around not using the adapter for the correct mounting unless you cut and weld the frame for the later box to clear [email protected] can answer your questions and makes this bracket is $55.00 plus $7.90 for shipping in the USA.
hope to have power-steering soon
2475
  #3
Old 10-29-2019, 12:41 PM
Junior Member
Default Idler arm change and position location
I already had the CPP adapter plates (inside/outside frame surface), power steering gearbox bolted up fine (after cleaning up a couple holes that didn't line up properly) and drilling threads out of the front lower mounting hole of the gearbox. I removed the idler arm from the '64 suspension assembly and it looks like it might work but the mount arm has a "jog" in it that would require making a spacer for. Additionally, since this is not a boxed frame, I would think it would be wise to add a stiffener plate to the inside of the frame where the idler arm bolts on. Is there a trick to knowing how far forward and "up" the idler needs to be bolted to the frame? Is a rough measurement with a tape measure adequate to locate correct position?
5478
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertisement
Partner Links
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
c10 trucks 67 72 c10 trucks c10 trucks for sale classic c10 trucks chevy c10 trucks used c10 trucks bagged c10 trucks slammed c10 trucks 1960 Chevy C10 Truck 1961 Chevy C10 Truck 1962 Chevy C10 Truck 1963 Chevy C10 Truck 1964 Chevy C10 Truck 1965 Chevy C10 Truck 1966 Chevy C10 Truck 1967 Chevy C10 Truck 1968 Chevy C10 Truck 1969 Chevy C10 Truck 1970 Chevy C10 Truck 1971 Chevy C10 Truck 1972 Chevy C10 Truck 1973 Chevy C10 Truck 1974 Chevy C10 Truck 1975 Chevy C10 Truck 1976 Chevy C10 Truck 1977 Chevy C10 Truck 1978 Chevy C10 Truck 1979 Chevy C10 Truck 1980 Chevy C10 Truck 1981 Chevy C10 Truck 1982 Chevy C10 Truck 1983 Chevy C10 Truck 1984 Chevy C10 Truck 1985 Chevy C10 Truck 1986 Chevy C10 Truck 1987 Chevy C10 Truck 1988 Chevy C10 Truck 1989 Chevy C10 Truck 1990 Chevy C10 Truck 1991 Chevy C10 Truck 1992 Chevy C10 Truck 1993 Chevy C10 Truck 1994 Chevy C10 Truck 1995 Chevy C10 Truck 1996 Chevy C10 Truck 1997 Chevy C10 Truck 1998 Chevy C10 Truck 1999 Chevy C10 Truck 2000 Chevy C10 Truck 2001 Chevy C10 Truck 1950 Chevrolet Truck 1968 C10 SNAKEBIT V-10 Hazel 1967 Chevrolet C10 BUILD 1968 C10 Chevrolet C10 Truck "5150" Plane Engine 68 c10 DINOS 1964 Chevrolet C10 DUALLY 1971 Chevrolet C10 "Pearl71" 1971 Brazilian style C10 1967 Chevrolet C10 Truck "Cloud9" C10 HISTORY AIR SUSPENSION Truck Frame Notches TYPES OF BODY DROP Patina Chevrolet Trucks The OKC Farm Truck Lambrecht Chevrolet Dealership C10 TRUCKS FOR SALE 1981 Chevrolet C-10 1972 Chevrolet C-10 s C10 Truck Racing crash FS 1960 Chevrolet C-10 FS 1972 Chevrolet C-10 Fs 1971 Chevrolet C-10 Fs 1970 Chevrolet C-10 Huge 1986 Chevy C10 4x4 NEW 1960 Chevrolet Apache Farmtruck Towing a Boat vs Twin Turbo Porsche Truck loading FAIL!! SOLID C10 Epic Chevy Truck Jump Fail What does 1000HP look like?  F 1967 Chevrolet C-10 Chevy Apache Twin Turbos F 1984 Chevrolet C10 What 3200HP of NOS Looks Like F 1972 Chevrolet C-10 1972 C-10 Texas Reaper  f 1978 Chevrolet C-10 2500 HP 632CI BBC chevy engine 1972 c10 SEMA ratrod F 1970 Chevrolet C-10 Full Size Chevy Jump Fail 1965 Chevrolet C-10 The Fastest Truck in the World f 1985 Chevrolet C-10 Stepside 1971 Chevrolet C-10 SHORT WHEEL BASE f. 1972 Chevrolet C-10 f. 1972 Chevrolet C-10 Ford Raptor Truck Jump Fail f 1981 Chevrolet C10 1971. Chevrolet C-10 Truck Jump and crash fail  A 1967 Chevrolet C-10 1971 Chevrolet C-10 1965 Chevrolet C-10  HOMECUTT 87 C10 chevy truck Arguing with a hater while Dragging my c10  Trent Eschete's '87 Chevy C10 Monster Truck Crashes Into Spectators Jerrys Jet Truck Full Video
