In need of some serious help - C10Trucks.com
Go Back   C10Trucks.com > 1st - 2nd and 3rd & 4th Generation Chevy C10 Trucks > First generation 1960–1966 Chevy C10 Trucks
First generation 1960–1966 Chevy C10 Trucks First generation 1960–1966 Chevy C10 Trucks
Old 01-22-2020, 12:30 AM
Slade64 Slade64 is offline
Default In need of some serious help
I apologize now, this will be a long explanation. For those of you that read it and reply, I thank you in advance.
I have a 64 c10 stepside that I bought from my grandfather when I was 15 and rebuilt in high school (straight 6 3 on the tree- 350 tpi w/ 700r4). During college and the building of my career I've carried her around with me. Garaged the whole time and on and off again getting it running and driving.
Here is the problem, I'm in a position now mentally and financially to start doing the things I have always wanted to do. However, since doing the motor swap in high school, i have disconnected from the rebuild life and at this point consider myself a newb (embarrassing considering my family restores and races classics).
I really want to dive into this and get started again. I can wrench and know basics. But I really dont know where to start. So my question is, for those of you that have let a truck sit, where did you start? I'll list some things I'm interested in doing down below.
Tires- already on the board, but what sizes are you running? Current stock 15" rims 6 lug
Coils- stock, 1 sagging, thinking of dropping
Brakes- stock, have new drums and pads
Rear end- stock, want to do posi, no idea what fits
Driveline is custom built and will hold up to posi
Drive line seal needs replaced- yay youtube
Interior is good, but needs upgrades.
Dash- thinking dakota digital
Seats- bench, needs reupholstering to match
Floor- carpet, needs new to match hump
These are just the things I can think of right now. Paint is good, but will need new after the rest is done. Any help, support, advice is more than appreciated. I live in Phoenix, so any good shops or parts houses recommendations are appreciated as well.
5938
Old 01-24-2020, 09:45 PM
Blue Goose's Avatar
Blue Goose Blue Goose is online now
Wow this can lead to a lot of questions so here is my 2 cents.
1-Tires-I don't like big tires and wheels(ie 18s and up)but I could go maybe 17 out back and 16 up front.I like wide tires in back.
2-Drop-I don't care for trucks slammed.A 3\4 drop is good [email protected] inch spindles and 1 inch springs up front.Depends on what rear is set up leaf or coil and yes Chevy did offer leaf back then.A lot of guys use complete front crossmember from 73 to 87 trucks.Its supposed to bolt right in only having to drill one hole per side.Most guys go for the ones with the 1 1\4 rotors.This gives you disc ,more modern suspension and more options of what you want to do.
3-Rear end-I think its already a 12 bolt just add a posi.Going with the 5 lug option then axles and drums could be drilled for that or go to a later model that aleady is 5 lug.
4-You-Its really a matter of what you like and what you want to end up with.Not sure then go to some car shows and see what others have done.Myself I like the sock factory look with just some subtle changes.Hp is a must and with gas prices overdrive to.Most of all have fun with your project.Good luck.
David
15
Old 01-29-2020, 11:20 PM
eburge eburge is online now
Blue Goose, could you expound on No. 3 (3-Rear end-I think its already a 12 bolt just add a posi. Going with the 5 lug option then axles and drums could be drilled for that or go to a later model that already is 5 lug.)
I'd like to add posi, 5 lug and disc to my 12 bolt rear end.
Thanx, Ermitt
2543
Old 01-29-2020, 11:28 PM
Thanks man, I appreciate the reply. It has been a, let's say, a brain fart for me because it's so many things I want to do. But at the same time back myself off and start practical.
I agree with your thoughts on rims/tires. I would like to keep the stock look in and out (minus the dakota digital dash). I love this era of trucks and would like to stick with it. Only difference being the stance. I'm curious to know what tire size everyone is running with for the 15" rims. Currently looking at 215/75r15.
I do have all 4 coils, P. Rear is sagging and needs replaced anyway. I was thinking a 3/5 drop, but it is a stepside and I'm worried about rubbing on the bed with a wider tire size.
With the rearend, this is above my knowledge. I'm sure I could figure it out, but tips are appreciated. It definitely needs more grip.
Jesus, again, long ass post.
5938
Old 02-07-2020, 05:34 PM
Blue Goose's Avatar
I think 72 models came 5 lug in 2wd models,but I'm nut sure about over all length.Might need to do some searching on rear diff dimensions.Otherwise you could have your drums and axles redrilled to 5 x5 pattern or if you want rear discs then just drill axles and get a kit for 5 lug.I'm running 255\70 15s on 15x8 rallies..60 series will add width but also lose height.
15
Old 02-16-2020, 01:19 AM
Just got new tires put on, went with the 205/75 r 15. From what I have read, this is the stock tire. I'm fine with that. But when I look at the clearance from the rear tire, being a stepside, it looks like i will rub on the fender well. With the tire size I want to drop it to fill up the well. But I'm reconsidering the 3/5.
I like that it is 6 lug, dont know why, but I do. This is what keeps me from the switch. I guess if I drop in the 70's front end and add PW steering. It would make sense. Not sure I want to do that yet. I really like the feel it has. Not to mention the great workout you get driving it lol.
5938
  #7
Old 05-27-2020, 12:55 PM
RoadTrip RoadTrip is online now
Slade64, I just finished putting a posi in place of the open carrier. Much of what you are asking depends on other things as I am sure you are aware. What engine? Which transmission? Mods to engine? You really should decide on these things before selecting a new rear end ratio. I have a big block with cam that comes on around 2300 rpm and am using a 700R4. No need in putting a ring/pinion ratio and torque converter that don't work in the power band of your truck. By knowing these things you can select the right wheel/tire diameter to make the engine run in its most efficient range. With my setup I am using a 4.1:1 posi with 16" tires. This puts me at the lower end of the power band of the engine. I also have some 15" wheels I can use as a standby. Talk to Yukon Gear, they have good products and can sell the axles you need to go with your wheel/stud choice. Hope this helps a little.
5478
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
c10 trucks 67 72 c10 trucks c10 trucks for sale classic c10 trucks chevy c10 trucks used c10 trucks bagged c10 trucks slammed c10 trucks 1960 Chevy C10 Truck 1961 Chevy C10 Truck 1962 Chevy C10 Truck 1963 Chevy C10 Truck 1964 Chevy C10 Truck 1965 Chevy C10 Truck 1966 Chevy C10 Truck 1967 Chevy C10 Truck 1968 Chevy C10 Truck 1969 Chevy C10 Truck 1970 Chevy C10 Truck 1971 Chevy C10 Truck 1972 Chevy C10 Truck 1973 Chevy C10 Truck 1974 Chevy C10 Truck 1975 Chevy C10 Truck 1976 Chevy C10 Truck 1977 Chevy C10 Truck 1978 Chevy C10 Truck 1979 Chevy C10 Truck 1980 Chevy C10 Truck 1981 Chevy C10 Truck 1982 Chevy C10 Truck 1983 Chevy C10 Truck 1984 Chevy C10 Truck 1985 Chevy C10 Truck 1986 Chevy C10 Truck 1987 Chevy C10 Truck 1988 Chevy C10 Truck 1989 Chevy C10 Truck 1990 Chevy C10 Truck 1991 Chevy C10 Truck 1992 Chevy C10 Truck 1993 Chevy C10 Truck 1994 Chevy C10 Truck 1995 Chevy C10 Truck 1996 Chevy C10 Truck 1997 Chevy C10 Truck 1998 Chevy C10 Truck 1999 Chevy C10 Truck 2000 Chevy C10 Truck 2001 Chevy C10 Truck 1950 Chevrolet Truck 1968 C10 SNAKEBIT V-10 Hazel 1967 Chevrolet C10 BUILD 1968 C10 Chevrolet C10 Truck "5150" Plane Engine 68 c10 DINOS 1964 Chevrolet C10 DUALLY 1971 Chevrolet C10 "Pearl71" 1971 Brazilian style C10 1967 Chevrolet C10 Truck "Cloud9" C10 HISTORY AIR SUSPENSION Truck Frame Notches TYPES OF BODY DROP Patina Chevrolet Trucks The OKC Farm Truck Lambrecht Chevrolet Dealership C10 TRUCKS FOR SALE 1981 Chevrolet C-10 1972 Chevrolet C-10 s C10 Truck Racing crash FS 1960 Chevrolet C-10 FS 1972 Chevrolet C-10 Fs 1971 Chevrolet C-10 Fs 1970 Chevrolet C-10 Huge 1986 Chevy C10 4x4 NEW 1960 Chevrolet Apache Farmtruck Towing a Boat vs Twin Turbo Porsche Truck loading FAIL!! SOLID C10 Epic Chevy Truck Jump Fail What does 1000HP look like?  F 1967 Chevrolet C-10 Chevy Apache Twin Turbos F 1984 Chevrolet C10 What 3200HP of NOS Looks Like F 1972 Chevrolet C-10 1972 C-10 Texas Reaper  f 1978 Chevrolet C-10 2500 HP 632CI BBC chevy engine 1972 c10 SEMA ratrod F 1970 Chevrolet C-10 Full Size Chevy Jump Fail 1965 Chevrolet C-10 The Fastest Truck in the World f 1985 Chevrolet C-10 Stepside 1971 Chevrolet C-10 SHORT WHEEL BASE f. 1972 Chevrolet C-10 f. 1972 Chevrolet C-10 Ford Raptor Truck Jump Fail f 1981 Chevrolet C10 1971. Chevrolet C-10 Truck Jump and crash fail  A 1967 Chevrolet C-10 1971 Chevrolet C-10 1965 Chevrolet C-10  HOMECUTT 87 C10 chevy truck Arguing with a hater while Dragging my c10  Trent Eschete's '87 Chevy C10 Monster Truck Crashes Into Spectators Jerrys Jet Truck Full Video
