Go Back   C10Trucks.com > 1st - 2nd and 3rd & 4th Generation Chevy C10 Trucks > Third generation 1973–1987 Chevy C10 Trucks
Third generation 1973–1987 Chevy C10 Trucks Third generation 1973–1987 Chevy C10 Trucks
New Page 1
Old 07-08-2017, 07:51 PM
heizlod heizlod is online now
Default all i wanted to do was replace a wheel bearing....
so, about 2 weeks ago i was driving home from work when i heard a loud popping sound and then my truck started pulling to the driver side. i pulled over and came to the conclusion that i had a broken wheel bearing(pic), being less than 10 miles from home, i limped very slowly home. lifted my truck up and pulled the wheel, immediately i noticed that my rotor had a deep groove in it(pic). you could tell that it had been there a while, previous owner obviously never bothered to fix it when he replaced the brake pads(pic). so before i did anything i know that new rotors, and pads would be needed along with the bearings. so my truck sits in my drive way till payday so i can get the parts i needed. payday comes and i go to pull everything off i realize that the hub wont come off. it was loose it would wiggle around, slide, but the bearing wouldn't slide off the spindle. called a friend over, he took a punch and hammer and beat on the bearing until it fell apart. pulled the hub off, cleaned up the spindle which had the inner ring still on it(pic). i beat on that, wouldn't come off, grabbed it with vise grips and twisted.....it still wouldn't come off. took a grinder and gently cut at the inner ring until it was almost cut thru. took a chisel and hammered away on it until it showed some movement. ok should be easy now right??? no. not my luck. i had to make another cut and then i was able to pull part of the inner ring off the spindle. the other part i had to hit with a hammer to get it off. (pic) as i look in wonder..... the inner ring had started to spin and FRICTION WELDED itself to the spindle. (pic) now i have to order new spindles, and of course those are only sold as sets. all i wanted to do was replace a bearing. so yeah thats been my last few weeks. how was yours???
the pictures below are so you can see my fun....
2743
Old 07-08-2017, 11:24 PM
cffisher's Avatar
cffisher cffisher is online now
Administrator
it maybe the p o over tightened the bearing when doing the brakes?
Charlie
Enjoying retirement
11
Old 07-09-2017, 12:18 AM
Hmmm. I didn't think of that. I'll know for sure once I pull the passenger side.
2743
Old 07-09-2017, 01:50 AM
406Rich's Avatar
406Rich 406Rich is online now
Administrator
Maybe never greased them correctly if at all, were they drop spindles or stock...? By the way no pics...!
`37 Ford Coupe, 406/350/324 posi
`64 C10, 350/350/373 posi
`68 Dodge Dart 370/904/325 sure grip
`69 Camaro RS/SS 350/350/307
106
Old 07-13-2017, 07:21 AM
there was grease there, not sure if there was enough. could be that they wasnt greased correctly. they were stock spindles.
as for the pictures im not sure, they are there for me. i just click on the links and they pop up.
2743
Old 07-13-2017, 09:37 AM
406Rich's Avatar
Administrator
Are your pics thru Photobucket...if so they won`t show....photobucket has a new policy..Recently Photobucket changed their "terms of use" so that one can no longer post pictures on websites without paying ~$33.00 per month..they are hlding your images hostage...
106
  #7
Old 07-13-2017, 10:23 AM
no i don't use photobucket, i attached them using the attachment icon at the top. the one that looks like a paperclip. i know that if in 5 years someone comes along to read this post and i have closed my photobucket account, they can no longer see the pictures which imo sucks. so i always try to attach the photos directly to the post.
2743
  #8
Old 07-14-2017, 01:28 AM
406Rich's Avatar
Administrator
There`s a photo attachment section in the first section when you come in to the forum ...http://www.c10trucks.com/forums/showthread.php?t=122
106
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
c10 trucks 67 72 c10 trucks c10 trucks for sale classic c10 trucks chevy c10 trucks used c10 trucks bagged c10 trucks slammed c10 trucks 1960 Chevy C10 Truck 1961 Chevy C10 Truck 1962 Chevy C10 Truck 1963 Chevy C10 Truck 1964 Chevy C10 Truck 1965 Chevy C10 Truck 1966 Chevy C10 Truck 1967 Chevy C10 Truck 1968 Chevy C10 Truck 1969 Chevy C10 Truck 1970 Chevy C10 Truck 1971 Chevy C10 Truck 1972 Chevy C10 Truck 1973 Chevy C10 Truck 1974 Chevy C10 Truck 1975 Chevy C10 Truck 1976 Chevy C10 Truck 1977 Chevy C10 Truck 1978 Chevy C10 Truck 1979 Chevy C10 Truck 1980 Chevy C10 Truck 1981 Chevy C10 Truck 1982 Chevy C10 Truck 1983 Chevy C10 Truck 1984 Chevy C10 Truck 1985 Chevy C10 Truck 1986 Chevy C10 Truck 1987 Chevy C10 Truck 1988 Chevy C10 Truck 1989 Chevy C10 Truck 1990 Chevy C10 Truck 1991 Chevy C10 Truck 1992 Chevy C10 Truck 1993 Chevy C10 Truck 1994 Chevy C10 Truck 1995 Chevy C10 Truck 1996 Chevy C10 Truck 1997 Chevy C10 Truck 1998 Chevy C10 Truck 1999 Chevy C10 Truck 2000 Chevy C10 Truck 2001 Chevy C10 Truck 1950 Chevrolet Truck 1968 C10 SNAKEBIT V-10 Hazel 1967 Chevrolet C10 BUILD 1968 C10 Chevrolet C10 Truck "5150" Plane Engine 68 c10 DINOS 1964 Chevrolet C10 DUALLY 1971 Chevrolet C10 "Pearl71" 1971 Brazilian style C10 1967 Chevrolet C10 Truck "Cloud9" C10 HISTORY AIR SUSPENSION Truck Frame Notches TYPES OF BODY DROP Patina Chevrolet Trucks The OKC Farm Truck Lambrecht Chevrolet Dealership C10 TRUCKS FOR SALE 1981 Chevrolet C-10 1972 Chevrolet C-10 s C10 Truck Racing crash FS 1960 Chevrolet C-10 FS 1972 Chevrolet C-10 Fs 1971 Chevrolet C-10 Fs 1970 Chevrolet C-10 Huge 1986 Chevy C10 4x4 NEW 1960 Chevrolet Apache Farmtruck Towing a Boat vs Twin Turbo Porsche Truck loading FAIL!! SOLID C10 Epic Chevy Truck Jump Fail What does 1000HP look like?  F 1967 Chevrolet C-10 Chevy Apache Twin Turbos F 1984 Chevrolet C10 What 3200HP of NOS Looks Like F 1972 Chevrolet C-10 1972 C-10 Texas Reaper  f 1978 Chevrolet C-10 2500 HP 632CI BBC chevy engine 1972 c10 SEMA ratrod F 1970 Chevrolet C-10 Full Size Chevy Jump Fail 1965 Chevrolet C-10 The Fastest Truck in the World f 1985 Chevrolet C-10 Stepside 1971 Chevrolet C-10 SHORT WHEEL BASE f. 1972 Chevrolet C-10 f. 1972 Chevrolet C-10 Ford Raptor Truck Jump Fail f 1981 Chevrolet C10 1971. Chevrolet C-10 Truck Jump and crash fail  A 1967 Chevrolet C-10 1971 Chevrolet C-10 1965 Chevrolet C-10  HOMECUTT 87 C10 chevy truck Arguing with a hater while Dragging my c10  Trent Eschete's '87 Chevy C10 Monster Truck Crashes Into Spectators Jerrys Jet Truck Full Video
